[Gdal-dev] gdal looking for proj "pj_get_def" function?
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 22 16:17:02 EST 2003
Brent Fraser wrote:
> Frank,
> I'm attempting to test gdal_warp (GDAL 1.1.8.0, Proj4.4.5) but it
> gives me an error message regarding "pj_get_def":
> X:\rawdata>gdalwarp -t_srs '+proj=utm +zone=11 +datum=WGS84' band1.tif
> UTM11_b1.tif
> ERROR 1: Can't find requested entry point: pj_get_def
> Usage: gdalwarp [--version] [--formats]
> [-s_srs srs_def] [-t_srs srs_def] [-order n] [-et err_threshold]
> [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
> [-of format] [-co "NAME=VALUE"]* srcfile dstfile
> Looking at the GDAL source (ogrct.cpp, line 220), I see where it is
> trying to get the symbol from proj.dll,
> but nowhere in my copy of the proj source does the function exist:
Brent,
I believe the message about not finding pj_get_def is unrelated to why
the gdalwarp is failing.
I think it is failing because you are using single quotes around the srs
argument. In the DOS shell
you need to use double quotes.
PS. pj_get_def is in the CVS version of PROJ.4, but isn't required by
GDAL. I will take steps
to ensure no error is reported to the user.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
