[Gdal-dev] Win32 binaries compiling ....
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 21 22:52:18 EST 2003
Cherkashin Evgeny wrote:
> On my system (Win 98) the process of compilation stops after
> considering only the first subdirectory in the "for" statenment
> subdirectories list. This is, probably, the old DOS bug. The
> compilation break does not allow all the drivers to be compiled, and,
> then, during linking process some gedalregister.... routines could not
> be found. The call statenment corrects this problem (at least for me).
> In essece for some systems there could be no change (as for You).
> Consider this as increase of reliability.
Evgeny,
OK, I have applied the change in gdal/frmts/makefile.vc and
gdal/ogr/ogrsf_frmts/Makefile.
Let me know if there are other places it should be done.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
