[Gdal-dev] ntf to postgres tables --- another problem
nida Khan nida at webstar.co.uk
Wed Jan 22 09:48:24 EST 2003
Sorry people,
It was the fault of actuall NTF  file... I have figured it out...
Regards
Nida.
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Wednesday, January 22, 2003 2:10 PM
Subject: [Gdal-dev] ntf to postgres tables --- another problem
> Hi List,
> I am trying to import NTF file into postgres table,
> There are 3 layers for this NTF file, it works fine for 2 of them but
fails
> on thrid one.
> This is the error I'm getting
> bash-2.05a$  ogr2ogr -update PG:dbname=test BIRMINGHAM_DISTRICT.NTF -lco
> "OVERWRITE=YES" "LAUNDER=YES" -nln birming_collection BL2000_COLLECTIONS
> ERROR 1: INSERT command for new feature failed.
> ERROR:  value too long for type character(6)
> ERROR 1: Terminating translation prematurely after failed
> translation of layer BL2000_COLLECTIONS
> I also tried to select few fields from that NTF file to a .dbf file but
that
> fails as welll due to integerList datatype.
> bash-2.05a$ ogr2ogr -select poly_id,census_code,admin_name shp_files/
> BIRMINGHAM_DISTRICT.NTF BL2000_COLLECTIONS
> ERROR 6: Can't create fields of type IntegerList on shapefile layers.
> Is there a way to resolve this problem???
> Regards
> Nida.
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
