[Gdal-dev] Re: gdal_merge.py
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 28 10:08:23 EST 2003
Hubert Fröhlich wrote:
> To my understanding, it seems to me it is the problem of matching the
> different colortables. I either
> - need to specify one colortable explicitly (I suppose from the first
> tile) and force gdal_merge.py to try to match colors for explicitly THIS
> colortable
> - or add the colors with their own colortables (as long as I know that I
> have always the same colortable, this would lead to a similar result.
Hubert,
The two input sample files you provided have different PCTs. The
-pct flag for gdal_merge.py just allows copying of a PCT (from the first
file in the set) to the output file. It doesn't do any merging of PCTs
or even remapping of image values to a common PCT.
In theory this could be added to gdal_merge.py, but I am concerned it
would complicated it substantially. Perhaps a separate script or program
could be written to read a bunch of files, establish a common optimized
color table and then remap the files to that colormap. Then as a
separate step these matching files could be merged.
However, such a script does not exist, and as it is a non-trivial
effort, I am not likely to do it in the near term. I am cc:ing this
message to the list in case someone else is interested attacking the
problem.
> Furthermore: gdal_merge seems to create a 24bit output, can I also
> produce 8bit (e.g. by adding a -ot switch?)
> c) I wanted merge two 24-bit colored orthophotos: I tried
> gdal_merge.py -o dopcol12.geotif dopcol2.geotif dopcol1.geotif
> which resulted in a 24-bit grayscale picture. (I can enclose on request)
> . How can I preserve color?
The existing gdal_merge.py ignores all bands but the first, so it doesn't
support 24bit (3 band) images properly. I have a patch from another user
to fix this that I could try and apply, and provide to you ... ok I have
applied it and it seems sensible but I haven't tested it. Could you do
that? It is attached (and in CVS).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
#!/usr/bin/env python
# $Id: gdal_merge.py,v 1.7 2003/01/28 15:00:13 warmerda Exp $
# Project: InSAR Peppers
# Purpose: Module to extract data from many rasters into one output.
# Author: Frank Warmerdam, warmerdam at pobox.com
# Copyright (c) 2000, Atlantis Scientific Inc. (www.atlsci.com)
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Library General Public
# License as published by the Free Software Foundation; either
# version 2 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Library General Public License for more details.
# You should have received a copy of the GNU Library General Public
# License along with this library; if not, write to the
# Free Software Foundation, Inc., 59 Temple Place - Suite 330,
# Boston, MA 02111-1307, USA.
# $Log: gdal_merge.py,v $
# Revision 1.7 2003/01/28 15:00:13 warmerda
# applied patch for multi-band support from Ken Boss
# Revision 1.6 2003/01/20 22:19:08 warmerda
# added nodata support
# Revision 1.5 2002/12/12 14:54:42 warmerda
# added the -pct flag to copy over a pct
# Revision 1.4 2002/12/12 14:48:12 warmerda
# removed broken options arg to gdal.Create()
# Revision 1.3 2002/04/03 21:12:05 warmerda
# added -separate flag for Gerald Buckmaster
# Revision 1.2 2000/11/29 20:36:18 warmerda
# allow output file to be preexisting
# Revision 1.1 2000/11/29 20:23:13 warmerda
# New
import gdal
import sys
import Numeric
verbose = 0
def raster_copy( s_fh, s_xoff, s_yoff, s_xsize, s_ysize, s_band_n,
t_fh, t_xoff, t_yoff, t_xsize, t_ysize, t_band_n,
nodata=None ):
if nodata is not None:
return raster_copy_with_nodata(
nodata )
if verbose != 0:
print 'Copy %d,%d,%d,%d to %d,%d,%d,%d.' \
% (s_xoff, s_yoff, s_xsize, s_ysize,
t_xoff, t_yoff, t_xsize, t_ysize )
s_band = s_fh.GetRasterBand( s_band_n )
t_band = t_fh.GetRasterBand( t_band_n )
data = s_band.ReadRaster( s_xoff, s_yoff, s_xsize, s_ysize,
t_xsize, t_ysize, t_band.DataType )
t_band.WriteRaster( t_xoff, t_yoff, t_xsize, t_ysize,
data, t_xsize, t_ysize, t_band.DataType )
return 0
def raster_copy_with_nodata( s_fh, s_xoff, s_yoff, s_xsize, s_ysize, s_band_n,
nodata ):
if verbose != 0:
data_src = s_band.ReadAsArray( s_xoff, s_yoff, s_xsize, s_ysize,
t_xsize, t_ysize )
data_dst = t_band.ReadAsArray( t_xoff, t_yoff, t_xsize, t_ysize )
nodata_test = Numeric.equal(data_src,nodata)
to_write = Numeric.choose( nodata_test, (data_src, data_dst) )
t_band.WriteArray( to_write, t_xoff, t_yoff )
return 0
def names_to_fileinfos( names ):
Translate a list of GDAL filenames, into file_info objects.
names -- list of valid GDAL dataset names.
Returns a list of file_info objects. There may be less file_info objects
than names if some of the names could not be opened as GDAL files.
file_infos = []
for name in names:
fi = file_info()
if fi.init_from_name( name ) == 1:
file_infos.append( fi )
return file_infos
class file_info:
"""A class holding information about a GDAL file."""
def init_from_name(self, filename):
Initialize file_info from filename
filename -- Name of file to read.
Returns 1 on success or 0 if the file can't be opened.
fh = gdal.Open( filename )
if fh is None:
return 0
self.filename = filename
self.bands = fh.RasterCount
self.xsize = fh.RasterXSize
self.ysize = fh.RasterYSize
self.band_type = fh.GetRasterBand(1).DataType
self.projection = fh.GetProjection()
self.geotransform = fh.GetGeoTransform()
self.ulx = self.geotransform[0]
self.uly = self.geotransform[3]
self.lrx = self.ulx + self.geotransform[1] * self.xsize
self.lry = self.uly + self.geotransform[5] * self.ysize
ct = fh.GetRasterBand(1).GetRasterColorTable()
if ct is not None:
self.ct = ct.Clone()
else:
self.ct = None
return 1
def report( self ):
print 'Filename: '+ self.filename
print 'File Size: %dx%dx%d' \
% (self.xsize, self.ysize, self.bands)
print 'Pixel Size: %f x %f' \
% (self.geotransform[1],self.geotransform[5])
print 'UL:(%f,%f) LR:(%f,%f)' \
% (self.ulx,self.uly,self.lrx,self.lry)
def copy_into( self, t_fh, s_band = 1, t_band = 1, nodata_arg=None ):
Copy this files image into target file.
This method will compute the overlap area of the file_info objects
file, and the target gdal.Dataset object, and copy the image data
for the common window area. It is assumed that the files are in
a compatible projection ... no checking or warping is done. However,
if the destination file is a different resolution, or different
image pixel type, the appropriate resampling and conversions will
be done (using normal GDAL promotion/demotion rules).
t_fh -- gdal.Dataset object for the file into which some or all
of this file may be copied.
Returns 1 on success (or if nothing needs to be copied), and zero one
failure.
t_geotransform = t_fh.GetGeoTransform()
t_ulx = t_geotransform[0]
t_uly = t_geotransform[3]
t_lrx = t_geotransform[0] + t_fh.RasterXSize * t_geotransform[1]
t_lry = t_geotransform[3] + t_fh.RasterYSize * t_geotransform[5]
# figure out intersection region
tgw_ulx = max(t_ulx,self.ulx)
tgw_uly = min(t_uly,self.uly)
tgw_lrx = min(t_lrx,self.lrx)
tgw_lry = max(t_lry,self.lry)
# do they even intersect?
if tgw_ulx >= tgw_lrx or tgw_uly <= tgw_lry:
return 1
# compute target window in pixel coordinates.
tw_xoff = int((tgw_ulx - t_geotransform[0]) / t_geotransform[1] + 0.1)
tw_yoff = int((tgw_uly - t_geotransform[3]) / t_geotransform[5] + 0.1)
tw_xsize = int((tgw_lrx - t_geotransform[0])/t_geotransform[1] + 0.5) \
- tw_xoff
tw_ysize = int((tgw_lry - t_geotransform[3])/t_geotransform[5] + 0.5) \
- tw_yoff
if tw_xsize < 1 or tw_ysize < 1:
return 1
# Compute source window in pixel coordinates.
sw_xoff = int((tgw_ulx - self.geotransform[0]) / self.geotransform[1])
sw_yoff = int((tgw_uly - self.geotransform[3]) / self.geotransform[5])
sw_xsize = int((tgw_lrx - self.geotransform[0]) \
/ self.geotransform[1] + 0.5) - sw_xoff
sw_ysize = int((tgw_lry - self.geotransform[3]) \
/ self.geotransform[5] + 0.5) - sw_yoff
if sw_xsize < 1 or sw_ysize < 1:
return 1
# Open the source file, and copy the selected region.
s_fh = gdal.Open( self.filename )
return \
raster_copy( s_fh, sw_xoff, sw_yoff, sw_xsize, sw_ysize, s_band,
t_fh, tw_xoff, tw_yoff, tw_xsize, tw_ysize, t_band,
nodata_arg )
def Usage():
print 'Usage: gdal_merge.py [-o out_filename] [-f out_format] [-v] [-pct]'
print ' [-ps pixelsize_x pixelsize_y] [-separate]'
print ' [-ul_lr ulx uly lrx lry] [-n nodata_value]'
print ' input_files'
print
# Program mainline.
if __name__ == '__main__':
names = []
format = 'GTiff'
out_file = 'out.tif'
ulx = None
psize_x = None
separate = 0
copy_pct = 0
nodata = None
# Parse command line arguments.
i = 1
while i < len(sys.argv):
arg = sys.argv[i]
if arg == '-o':
i = i + 1
out_file = sys.argv[i]
elif arg == '-v':
verbose = 1
elif arg == '-separate':
separate = 1
elif arg == '-pct':
copy_pct = 1
elif arg == '-n':
i = i + 1
nodata = int(sys.argv[i])
elif arg == '-f':
i = i + 1
format = sys.argv[i]
elif arg == '-ps':
psize_x = float(sys.argv[i+1])
psize_y = -1 * abs(float(sys.argv[i+1]))
i = i + 2
elif arg == '-ul_lr':
ulx = float(sys.argv[i+1])
uly = float(sys.argv[i+2])
lrx = float(sys.argv[i+3])
lry = float(sys.argv[i+4])
i = i + 4
elif arg[:1] == '-':
Usage()
sys.exit( 1 )
else:
names.append( arg )
i = i + 1
if len(names) == 0:
Usage()
sys.exit( 1 )
Driver = gdal.GetDriverByName(format)
if Driver is None:
print 'Format driver %s not found, pick a supported driver.' % format
sys.exit( 1 )
# Collect information on all the source files.
file_infos = names_to_fileinfos( names )
if ulx is None:
ulx = file_infos[0].ulx
uly = file_infos[0].uly
lrx = file_infos[0].lrx
lry = file_infos[0].lry
for fi in file_infos:
ulx = min(ulx, fi.ulx)
uly = max(uly, fi.uly)
lrx = max(lrx, fi.lrx)
lry = min(lry, fi.lry)
if psize_x is None:
psize_x = file_infos[0].geotransform[1]
psize_y = file_infos[0].geotransform[5]
# Try opening as an existing file.
t_fh = gdal.Open( out_file, gdal.GA_ReadOnly )
# Create output file if it does not already exist.
if t_fh is None:
geotransform = [ulx, psize_x, 0, uly, 0, psize_y]
xsize = int((lrx - ulx) / geotransform[1])
ysize = int((lry - uly) / geotransform[5])
if separate != 0:
bands = len(file_infos)
else:
# bands = 1
bands = file_infos[0].bands
t_fh = Driver.Create( out_file, xsize, ysize, bands,
file_infos[0].band_type )
t_fh.SetGeoTransform( geotransform )
if copy_pct:
t_fh.GetRasterBand(1).SetRasterColorTable(file_infos[0].ct)
# Copy data from source files into output file.
t_band = 1
if verbose != 0:
print
fi.report()
if separate == 0 :
for band in range(1, bands+1):
fi.copy_into( t_fh, band, band, nodata )
else:
fi.copy_into( t_fh, 1, t_band, nodata )
t_band = t_band+1
# Force file to be closed.
t_fh = None
