[Gdal-dev] Re: gdalwarp transparent fill
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 4 10:42:04 EDT 2003
list67 at netscape.net wrote:
> Mr. Warmerdam,
> Hello. Yesterday, I sent the attatched message to the gdal-dev mailing list,
> and it has not appeared yet on the mailing list web page. Do you know if
> messages from @netscape.net are filtered from the list? Thanks.
Mike,
I don't know what happened to your email. It didn't come through on the list
either. I don't think there is any filtering on the list other than to bounce
messages from folks that are not members.
> Subject: gdalwarp transparent fill From: list67 Date: Wed, 02 Jul 2003 20:00:20 -0400 To: gdal-dev at remotesensing.org
> Hello. I've been using the gdalwarp program to reproject some geotiff files. It works great. The reprojected
> geotiffs usually (maybe always) have some black areas around the edges due to the reprojection. Instead of the black
> pixels, I would like the pixels to be transparent. I've been using GIMP to add an alpha channel and cut out the
> black areas. So, I was hoping that gdal_warp might be able to do all of this for me. Has anyone used gdal_warp in
> this way? If it is not too complicated, would you tell me what I need to do in order to use gdal_warp in this way?
Gdalwarp won't do this, but I would like to modify gdalwarptest (the next
generation warper to do it) though it doesn't yet. Are you willing to test
it if I implementing it in CVS? Are you setup to be able to build GDAL from
CVS or a CVS snapshot?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
