[Gdal-dev] gdal w/ grass support
Richard Greenwood
Rich at GreenwoodMap.com
Thu Jul 10 09:37:23 EDT 2003
That was it. Thanks so much. Sorry to clutter the list with such a basic
problem.
Rich
At 09:34 AM 7/10/2003 +0200, you wrote:
>On Thursday 10 July 2003 06:18, Richard Greenwood wrote:
> > I am having trouble getting gdal going with grass support. I built and
> > installed libgrass without any apparent errors. The I built gdal (configure
> > --with-grass=/usr/local/lib) without any apparent errors. But when I run
> > gdalinfo I get
> > "error while loading shared libraries: libgrass5.so.0: cannot open shared
> > object file: No such file or directory".
> > libgrass5.so.0 is a symbolic link in /usr/local/lib and /usr/local/lib is
> > in my path.
>It should not be in your path, but in your dynamic library path. You can set
>this by adding /usr/local/lib to the environment variable LD_LIBRARY_PATH, or
>add it to the file /etd/ld.so.conf (which you might prefer because this will
>add /usr/local/lib to the standard places where the dynamic linker will look
>for libraries). After that, run ldconfig as root.
>Cheers,
>Vincent.
> > Sorry for what I suspect is a pretty trivial question.
> > Thanks,
> > Rich
> > Richard W. Greenwood, PLS
> > Greenwood Mapping, Inc.
> > Rich <at> GreenwoodMap <dot> com
> > (307) 733-0203
> > http://www.GreenwoodMap.com
>______________________________________
>Vincent Schut
>Sarvision B.V.
>Wageningen, The Netherlands
>www.sarvision.com
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
(307) 733-0203
