[Gdal-dev] projected bounding box
Jonathan Coles
jonathan at intevation.de
Wed Jul 16 04:03:14 EDT 2003
On Mon, 2003-07-14 at 20:29, Frank Warmerdam wrote:
> Jonathan,
> As Ed mentions this is hard to do completely correctly. The
> GDALSuggestedWarpOutput() is where I have it implemented for the image
> warper applications. This code basically samples 20 points along each edge
> to transform and compute a bounding box. This generally gives good results,
> but objects it can be off a bit or even alot in degenerate situations.
> You might want to glance at gdal/alg/gdaltransformer.cpp::GDALSuggsestedWarpOutput().
Thanks, I'm looking into playing around with different amounts of
sampling in my own code. Seems to be working alright for my test cases.
I'll have to watch out for extreme situations.
--jonathan
Jonathan Coles jonathan at intevation.de
Intevation GmbH http://www.intevation.de
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030716/54fafe6d/attachment.bin
