[Gdal-dev] static libraries revamped (was: new build strategy for org/orgsf_frmts/)
Norman Vine
nhv at cape.com
Thu Jul 24 10:38:37 EDT 2003
Amici Alessandro writes:
> you mean:
> $ g++ -Wl,--relocateable -o ogr.o ogrcurve.o ogrlinestring.o
> ogrlinestring.o(.eh_frame+0x67c):ogrlinestring.cpp: reloc refers to symbol
> `.text$_ZN8OGRCurveD0Ev' which is not being output
> ogrlinestring.o(.eh_frame+0x6a8):ogrlinestring.cpp: reloc refers to symbol
> `.text$_ZN8OGRCurveD1Ev' which is not being output
> collect2: ld returned 1 exit status
> no luck :(
Oh well it was worth a try
Hmm.... I just noticed this in the ld docs
`-Ur'
For anything other than C++ programs, this option is equivalent to
`-r': it generates relocatable output--i.e., an output file that
can in turn serve as input to `ld'. When linking C++ programs,
`-Ur' _does_ resolve references to constructors, unlike `-r'. It
does not work to use `-Ur' on files that were themselves linked
with `-Ur'; once the constructor table has been built, it cannot
be added to. Use `-Ur' only for the last partial link, and `-r'
for the others.
so maybe
ld -Ur -o ogr.o ogrcurve.o ogrlinestring.o
If that doesn't work maybe a question to gcc-help at gcc.gnu.org
is in order
Cheers
Norman
