[Gdal-dev] gdal to proj4 translation
Amici Alessandro
alessandro_amici at telespazio.it
Thu Jul 24 11:08:39 EDT 2003
Frank,
i'm working on a DEM reader and i wuold be glad to use gdal and proj4
as fromat and projection engines. my question is: is there an easy way to
convert the gdal representation of the projections (the opengis format
if i understand correctly) and the proj4 strings?
digging into the docs i found the OGRSpatialReference class, which looks
like
a good starting point, but is it the shortest path?
thanks,
alessandro
