[Gdal-dev] GDAL on OS X
Sean Fulton
fulton at cmu.edu
Tue Jul 29 10:51:39 EDT 2003
I'm trying to compile GDAL on OS X. The compile seems to fail at the
linking stage. Can anyone suggest what the problem might be?
Thanks.
Sean
ranlib ./gdal.a
ranlib: file: ./gdal.a(pnggccrd.o) has no symbols
ranlib: file: ./gdal.a(pngvcrd.o) has no symbols
ranlib: file: ./gdal.a(tif_pixarlog.o) has no symbols
ranlib: file: ./gdal.a(cpl_vsil_unix_stdio_64.o) has no symbols
make ./libgdal.1.1.dylib
gcc -dynamiclib ./frmts/o/*.o ./gcore/*.o ./port/*.o ./alg/*.o
./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_fromepsg.o
./ogr/ogr_srs_validate.o ./ogr/ogrutils.o ./ogr/ogr_srs_proj4.o
./ogr/ograssemblepolygon.o ./ogr/ogr_api.o
./ogr/ogrsf_frmts/generic/ogrregisterall.o ./ogr/ogrfeaturestyle.o
./ogr/ogrsf_frmts/ogrsf_frmts.a ./gdal.a ./ogr/ogr.a ./gdal.a
./port/cpl.a -lz -lm -lm \
-o ./libgdal.1.1.dylib
ld: Undefined symbols:
/usr/bin/libtool: internal link edit command failed
vtable for __cxxabiv1::__class_type_info
vtable for __cxxabiv1::__si_class_type_info
operator delete(void*)
operator new(unsigned long)
___gxx_personality_v0
operator delete[](void*)
operator new[](unsigned long)
___cxa_pure_virtual
vtable for __cxxabiv1::__vmi_class_type_info
make[1]: *** [libgdal.1.1.dylib] Error 1
make: *** [check-lib] Error 2
