[Gdal-dev] CPL_DLL CSVDeaccess
Ben Discoe ben at vterrain.org
Fri Jun 27 11:33:55 EDT 2003
I have discovered there is no way to clean up the CSV cache at exit,
unless you have called GDALAllRegister/GDALDestroyDriverManager which
triggers the GeoTIFF module to clean up.
Since the CSV stuff is used heavily by the OGR coordinate system stuff
(not just the GDAL/GeoTIFF code), there needs to be way for apps using
OGR to clean up the CSV cache.
I found that calling CSVDeaccess is sufficient, but the following tiny
change is needed on Windows:
RCS file: /cvsroot/osrs/gdal/port/cpl_csv.h,v
retrieving revision 1.1
63c63
< void  CSVDeaccess( const char * );
> void  CPL_DLL CSVDeaccess( const char * );
Thanks,
Ben
