[Gdal-dev] "core" renamed to "gcore"
Fri Jun 27 15:08:08 EDT 2003
Folks,
This is just to warn that I am changing the name of the gdal/core directory
to gdal/gcore to avoid all the problems with configure scripts trying to
delete it.  Things will be in flux for a bit due to this.  Anyone with a
CVS tree checked out will need to do "cvs update -d" in the main gdal directory
to get the new directory checked out, and the old one will likely have to
be removed manually.
I expect to have a gdal-1.1.9 beta up for review later this afternoon.
Best regards,
