[Gdal-dev] Gettting Image Resolution
Frank Warmerdam
warmerdam at pobox.com
Sun Mar 2 12:21:35 EST 2003
Ayman Kamal wrote:
> How can I get the resolution of the image using GDAL?
I assume you are wanting the size of a pixel in georeferenced coordinates?
If so, use the GetGeoTransform() method on the GDALDataset. It fills in a
six parameter double array. geotransform[1] is normally the width of a
pixel, and geotransform[5] is usually the height of a pixel negated.
If the image is rotated things are more complicated.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
