R: [Gdal-dev] Error messages
Frank Warmerdam
warmerdam at pobox.com
Sun Mar 2 12:24:34 EST 2003
>>>In C or C++ call "GDALSetErrorHandler(
>>CPLQuietErrorHandler );".
>>is there any way to do it from python?
>>i don't need to attach an handler, just to silence
>>the errors.
Alessandro,
I have added PushErrorHandler(), PopErrorHandler(), and Error() methods
in the "gdal" module. The PushErrorHandler() takes either the name of a
well known error handler, or a Python function to invoke.
For example:
import gdal
def MyHandler( err_class, err_code, msg ):
print err_class, err_code, msg
gdal.Error( msg = 'Test Message' )
gdal.PushErrorHandler( "CPLQuietErrorHandler" )
gdal.Error( msg = 'Test Message 2' )
gdal.PushErrorHandler( MyHandler )
gdal.Error( msg = 'Test Message 3' )
gdal.Debug( 'test1', 'message' )
gdal.PopErrorHandler()
gdal.Error( msg = 'Test Message 4' )
gdal.Error( msg = 'Test Message 5' )
Produces:
warmerda at gdal2200[40]% ./test1.py
ERROR 1: Test Message
3 1 Test Message 3
1 0 Sun Mar 2 12:23:26 2003: test1: message
ERROR 1: Test Message 5
As you can see, "gdal.PushErrorHandler( 'CPLQuietHandler' )" should be
sufficient for your needs. The error handler mechanism can also be
used to redirect debug output.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
