[Gdal-dev] help !
Anand Madhavan
anandm at ittc.ku.edu
Thu Mar 6 22:58:09 EST 2003
I basically need to get ALL the information about a .img (hfa) file
header and copy it into another .img (hfa) file I create with my own new
data. Can anyone help me as to what API's I should use and where to look for
them ? Any help is highly appreciated. Thank you.
Regards,
Anand
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of
gdal-dev-request at remotesensing.org
Sent: Thursday, February 27, 2003 11:00 AM
To: gdal-dev at remotesensing.org
Subject: Gdal-dev digest, Vol 1 #75 - 12 msgs
Send Gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://remotesensing.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Gdal-dev digest..."
Today's Topics:
1. hdf4 metadata (Norman Vine)
2. Re: hdf4 metadata (Andrey Kiselev)
3. RE: hdf4 metadata (Norman Vine)
4. Re: R: [Gdal-dev] Support for creating ENVI .hdr labeled files (Andrey
Kiselev)
5. R: R: [Gdal-dev] Support for creating ENVI .hdr labeled files (Amici
Alessandro)
6. Re: hdf4 metadata (Andrey Kiselev)
7. RE: hdf4 metadata (Norman Vine)
8. customizing GDAL to make only two drivers available (Ayman Kamal)
9. RE: customizing GDAL to make only two drivers available (Norman Vine)
10. Re: customizing GDAL to make only two drivers available (Frank
Warmerdam)
11. Re: hdf4 metadata (Andrey Kiselev)
12. RE: hdf4 metadata (Norman Vine)
--__--__--
Message: 1
To: <gdal-dev at remotesensing.org>
Date: Wed, 26 Feb 2003 17:38:05 -0500
Subject: [Gdal-dev] hdf4 metadata
Reply-To: gdal-dev at remotesensing.org
Hi All
I am not sure if the following is a problem with GDAL
or my hdf4 library
With gdalinfo I constantly get
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
GPOLYGONCONTAINER=-103.892405, -81.954139, -86.270138, -107.052668
GRINGPOINTLATITUDE=20.525827, 17.337449, -0.496254, 2.465055
GRINGPOINTSEQUENCENO=1, 2, 3, 4
the data for GRPOLYGONCONTAINER is I would expect for
GRINGPOINTLONGITUDE
Is anyone else seeing this ?
This is using Cygwin
Cheers
Norman
--__--__--
Message: 2
Date: Thu, 27 Feb 2003 10:00:30 +0300
Subject: Re: [Gdal-dev] hdf4 metadata
Norman,
> or my hdf4 library
> Size is 512, 512
> Metadata:
> GRINGPOINTLONGITUDE
What HDF products used by you? What size of this datasets? If them has a
reasonable size, I want get the sample.
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
--__--__--
Message: 3
Subject: RE: [Gdal-dev] hdf4 metadata
Date: Thu, 27 Feb 2003 04:52:33 -0500
Andrey Kiselev writes:
> > or my hdf4 library
> > Size is 512, 512
> > Metadata:
> > GRINGPOINTLONGITUDE
Hi Andrey
I am working with MODIS data
There are l2 and l3 data sets in the 'images' directory of
the MODIS Ocean Color tutorial
http://jeager.gsfc.nasa.gov/modis_workshop_unh/
I suggest that we use these as our 'standard' MODIS test files
Note I hope to eventually be able to duplicate the functionality of the
matlab and IDL code in this tutorial with GDAL and Python
Cheers
Norman
--__--__--
Message: 4
Date: Thu, 27 Feb 2003 12:58:32 +0300
Subject: Re: R: [Gdal-dev] Support for creating ENVI .hdr labeled files
Amici,
On Wed, Feb 26, 2003 at 12:47:34PM +0100, Amici Alessandro wrote:
> in addition to the WIP-items you mentioned i'd like to point out to you
> one more useful item to implement:
> an option to _append_ the '.hdr' extension to the full name i.e.
> image.bin -> image.bin.hdr
I have implemented such an option. Try "SUFFIX=ADD" with gdal_translate.
By default suffix will be replaced as previously.
Andrey V. Kiselev
--__--__--
Message: 5
From: Amici Alessandro <alessandro_amici at telespazio.it>
Subject: R: R: [Gdal-dev] Support for creating ENVI .hdr labeled files
Date: Thu, 27 Feb 2003 11:36:18 +0100
hi,
> Amici,
Andrey, my first name is Alessandro :) and unfortunately i have no power to
change the broken mailer with this stupid 'second name first' default :(
i tryed both SUFFIX and INTERLEAVE, and found no problem :).
thanks a lot, this seriously cuts down the number of quirks i need to
implement in my apps!
i will stress test the ENVI driver from now on. if you need testing on
specific
areas (i.e. map_info), don't esitate to cc me directly.
cheers,
alessandro
--__--__--
Message: 6
Date: Thu, 27 Feb 2003 13:41:01 +0300
Norman,
What GDAL version do you use?
Andrey V. Kiselev
--__--__--
Message: 7
Date: Thu, 27 Feb 2003 06:02:51 -0500
> Norman,
Yesterday's CVS
Cheers
Norman
--__--__--
Message: 8
Date: Thu, 27 Feb 2003 04:00:55 -0800 (PST)
Subject: [Gdal-dev] customizing GDAL to make only two drivers available
Is there any means to minimize the numbers of drivers
available in GDAL so that I can use it just to convert
from format "A" to format "B", I guess this way it
will be lighter weight. Can I do this? How?
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
--__--__--
Message: 9
Subject: RE: [Gdal-dev] customizing GDAL to make only two drivers available
Date: Thu, 27 Feb 2003 07:16:57 -0500
Ayman Kamal writes:
If I remember correctly you are using MSVC
in which case I believe that you can modify the
$GDAL_SRC/frmts/makefile.vc EXTRAFLAGS variable
to just include the formats you want
ie this should yield a GDAL that only did tiff and bmp
EXTRAFLAGS = -DFRMT_gtiff -DFRMT_bmp
on Unix like systems you need to modify the
$GDAL_SRC/GDALmake.opt file variable $GDAL_FORMATS
HTH
Norman
--__--__--
Message: 10
Date: Thu, 27 Feb 2003 09:11:53 -0500
Subject: Re: [Gdal-dev] customizing GDAL to make only two drivers available
Norman Vine wrote:
> Ayman Kamal writes:
Ayman,
Norman is right on this, though you can only control what gets
included by subdirectory of gdal/frmts, so for instance, to get any
driver in the frmts/raw directory you normally get them all. However, they
are "light". There are also a few dependencies between drivers that may
come
up.
I would add that you can save alot by not including the OGR drivers in a
GDAL
build where you only need raster support.
On windows set comment out the "INCLUDE_OGR_FRMTS" flag setting to disable
inclusino of OGR.
On Unix configure with the "--without-ogr" switch.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
--__--__--
Message: 11
Date: Thu, 27 Feb 2003 17:40:13 +0300
Norman,
I have fixed problem with HDF-EOS metadata parsing. You could check out
latest changes.
Andrey V. Kiselev
--__--__--
Message: 12
Date: Thu, 27 Feb 2003 10:04:39 -0500
> latest changes.
Yes *much* better :-)
Thanks !
Norman
--__--__--
Gdal-dev at remotesensing.org
End of Gdal-dev Digest
