[Gdal-dev] GDAL Translate and PNM format
Andrey Kiselev dron at ak4719.spb.edu
Mon Mar 10 02:36:31 EST 2003
On Mon, Mar 10, 2003 at 12:10:45AM -0500, Jim Julian wrote:
>    The switches work, of course, but the bil format turned out to be of
> a type not compatible with the PNM format (INT16). I settled for GeoTiff.
You can safely convert Int16 into UInt16 (with -ot switch) if you have
only positive values in input file.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
