[Gdal-dev] Landsat 7 data
Andrey Kiselev
dron at ak4719.spb.edu
Wed Mar 12 08:08:46 EST 2003
On Wed, Mar 12, 2003 at 01:30:01PM +0100, Horst Reinecke wrote:
> i trying to read FASTL7 data with grass5.0 (r.in.gdal) or gdalinfo. Both
> times i get the answer "ERROR 4: <filename> not recognised as supported
> fileformat". I using gdal-bibliothek 1.1.8. What wrong?
Probably you supply r.in.gdal with wrong file. You should read header
file, not the binary image itself.
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
