Am Mittwoch, 12. März 2003 14:34 schrieben Sie:
> On Wed, Mar 12, 2003 at 02:21:15PM +0100, Horst Reinecke wrote:
> > > > i trying to read FASTL7 data with grass5.0 (r.in.gdal) or gdalinfo.
> > > > Both times i get the answer "ERROR 4: <filename> not recognised as
> > > > supported fileformat". I using gdal-bibliothek 1.1.8. What wrong?
> > > Probably you supply r.in.gdal with wrong file. You should read header
> > > file, not the binary image itself.
> > Thanks, but I took the headerfiles xxx_hpn.fst xxx_hfr.fst and
> > xxx_htm.fst.
> Send your header files to me, please.
REQ ID =0750012120075_0049 LOC =169/0720000 ACQUISITION DATE =20001009
SATELLITE =LANDSAT7 SENSOR =ETM+ SENSOR MODE =NORMAL LOOK ANGLE =0.00
LOCATION = ACQUISITION DATE =
SATELLITE = SENSOR = SENSOR MODE = LOOK ANGLE =
PRODUCT TYPE =MAP ORIENTED PRODUCT SIZE =FULL SCENE
TYPE OF PROCESSING =SYSTEMATIC RESAMPLING =NN
VOLUME #/# IN SET =01/01 PIXELS PER LINE =15781 LINES PER BAND =13961/13961
START LINE # = BLOCKING FACTOR = REC SIZE =220318541 PIXEL SIZE =15.00
OUTPUT BITS PER PIXEL =8 ACQUIRED BITS PER PIXEL =8
BANDS PRESENT =8
FILENAME =L72169072_07220001009_B80.FSTFILENAME =
FILENAME = FILENAME =
REV L7A
GAINS AND BIASES IN ASCENDING BAND NUMBER ORDER
-4.699999809265137 0.971764729069728
GEOMETRIC DATA MAP PROJECTION =UTM ELLIPSOID =WGS84 DATUM =WGS84
USGS PROJECTION PARAMETERS = 0.000000000000000 0.000000000000000
0.000000000000000 0.000000000000000 0.000000000000000
0.000000000000000 USGS MAP ZONE =-36
UL = 0305842.2428E 162348.3658S 284100.000 8186100.000
UR = 0331141.3022E 162423.0426S 520800.000 8186100.000
LR = 0331148.5352E 181757.1331S 520800.000 7976700.000
LL = 0305727.2443E 181718.1952S 284100.000 7976700.000
CENTER = 0320454.6821E 172103.0083S 402450.000 8081400.000 7891 6981
OFFSET =-3236 ORIENTATION ANGLE =0.00
SUN ELEVATION ANGLE =59.9 SUN AZIMUTH ANGLE =72.2
VOLUME #/# IN SET =01/01 PIXELS PER LINE =7891 LINES PER BAND =6981 /6981
START LINE # = BLOCKING FACTOR = REC SIZE =55087071 PIXEL SIZE =30.00
BANDS PRESENT =123457
FILENAME =L71169072_07220001009_B10.FSTFILENAME =L71169072_07220001009_B20.FST
FILENAME =L71169072_07220001009_B30.FSTFILENAME =L71169072_07220001009_B40.FST
FILENAME =L71169072_07220001009_B50.FSTFILENAME =L72169072_07220001009_B70.FST
REV L7A
-6.199999809265137 0.775686297697179
-6.400000095367432 0.795686274883794
-5.000000000000000 0.619215662339154
-5.099999904632568 0.965490219639797
-1.000000000000000 0.125725488101735
-0.349999994039536 0.043725490920684
CENTER = 0320454.6821E 172103.0083S 402450.000 8081400.000 3946 3491
VOLUME #/# IN SET =01/01 PIXELS PER LINE =3946 LINES PER BAND =3491 /3491
START LINE # = BLOCKING FACTOR = REC SIZE =13775486 PIXEL SIZE =60.00
BANDS PRESENT =LH
FILENAME =L71169072_07220001009_B61.FSTFILENAME =L72169072_07220001009_B62.FST
REV L7A
0.000000000000000 0.066823533002068
3.200000047683716 0.037058821846457
CENTER = 0320454.6821E 172103.0083S 402450.000 8081400.000 1973 1746
