[Gdal-dev] IRasterIO Problems?
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 17 16:04:20 EST 2003
Simon Perkins wrote:
> Just a heads up that I've started getting a segmentation fault using
> existing code with the latest version of GDAL. My code works fine with
> the version of GDAL in CVS prior to March 9th. On that date a bunch of
> changes were checked in for rasterio.cpp and the problem seems to be in
> that file.
> The problem occurs loading in smallish windows (50x50ish) from a medium
> sized (450x400ish) four-band byte FITS image.
> More news when I get it, unless someone has already solved something
> like this and lets me know first!
Sy,
I found a few bugs were introduced March 7-9 and I committed some fixes
on March 13th. Ensure you have rasterio.cpp 1.22 checked out. If problems
persist I would encourage you to report bugs to Andrey (dron at remotesensing.org)
to fix.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
