[Gdal-dev] problem with converting GeoTiff to BMP
Norman Vine
nhv at cape.com
Sun Mar 23 11:12:43 EST 2003
Ayman Kamal writes:
> I have a GeoTiff file with the following data
> generated from "gdalinfo". I converted this file using
> "gdal_translate" to a bmp file, it appeared as all
> white, but when I chose to call
> "poVRTBand->AddSimpleSource"
> instead of
> "poVRTBand->AddComplexSource"
> it worked,
> Can you tell me why?
> Driver: GTiff/GeoTIFF
> Band 1 Block=375x1 Type=Float32, ColorInterp=Gray
only 1 Band is a "SIMPLE SOURCE"
HTH
Norman
