[Gdal-dev] Error while loading shared libraries: libgdal.1.1.so
Øystein Bedin
oystein.bedin at gold.sdsmt.edu
Thu Mar 27 03:01:30 EST 2003
The only build-instructions I found is on this page:
http://www.remotesensing.org/gdal/gdal_building.html
I couldn't find anything about 'make install' and 'ldconfig' there... So if
there's something I'm missing here -please tell me.
This is what I did:
./configure --with-hdf4=/hdf
make
I tried to run the make install aftwards - I still get the same error:
"Error while loading shared libraries: libgdal.1.1.so: cannot open shared
object file: No such file or directory."
Thanks
- Øystein
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Wednesday, March 26, 2003 11:52 PM
Subject: Re: [Gdal-dev] Error while loading shared libraries: libgdal.1.1.so
> > shared object file: No such file or directory."
> > Seems like the make process is going as it is supposed to - no errors.
> > Any suggestions about what the problem might be?
> Do you complete all building steps, including `make install' and
> `ldconfig' after all?
> Regards,
> Andrey
> Andrey V. Kiselev
> Home phone: +7 812 5274898 ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
