[Gdal-dev] python support under cygwin?
Norman Vine
nhv at cape.com
Wed May 14 16:09:19 EDT 2003
Amici Alessandro writes:
> i installed Numeric-23.0 on cygwin in order to get python-gdal support.
> on:
> $ ./configure --withou-ld-shared
> $ make
> everything is ok, but on:
> # make install
> i get the following error:
> /bin/true gdal_wrap.o numpydataset.o gdalnumeric.o \
> -L.. -lgdal.1.1 -ljpeg -ltiff -lpng -lz -lm -lm -o _gdalmodule.so
> ../install-sh -d /usr/lib/python2.2/site-packages
> for f in *.py _gdalmodule.so ; do ../install-sh -c $f
> ckages ; done
> install: _gdalmodule.so does not exist
> make[1]: *** [install] Error 1
> make[1]: Leaving directory
> `/cygdrive/c/home/amici/devel/gdal-cvs-030509/pymod'
> make: *** [install-actions] Error 2
> the problem is linked to the lack of shared libraries
> (LD_SHARED=/bin/true)
> on cygwin, which are assumed to be present in pymod/GNUmakefile.
> is there any chance to get python support under cygwin?
the Python extension works well with Cygwin
> have you (or anybody else) any idea on what needs to be done?
> should i file a bug?
Just tweak the Makefile(s) a little :-)
Cheers
Norman
==== cut ====
GDAL_ROOT = ..
include ../GDALmake.opt
GDALMODULE = _gdalmodule.$(SO_EXT)
OBJ = gdal_wrap.o numpydataset.o gdalnumeric.o
PY_VER = python2.3
PYTHON_LIB = -L/usr/local/lib/$(PY_VER)/config -l$(PY_VER).$(SO_EXT)
default: $(GDALMODULE)
clean:
rm -f *.o *.$(SO_EXT)
%.o: %.c
$(CC) -c -I. $(GDAL_INCLUDE) $(PYTHON_INCLUDES)\
$(CFLAGS) -DUSE_DL_IMPORT $(NUMPY_FLAG) $*.c -o $*.o
%.o: %.cpp
$(CXX) -c -I. $(GDAL_INCLUDE) $(PYTHON_INCLUDES) \
$(CXXFLAGS) -DUSE_DL_IMPORT $(NUMPY_FLAG) $*.cpp -o $*.o
gdal_wrap.c: gdal.i
-swig -python gdal.i
$(GDALMODULE): $(OBJ) $(GDAL_LIB) $(GDAL_SLIB)
$(LD_SHARED) $(OBJ) \
$(GDAL_SLIB_LINK) $(LIBS) $(PYTHON_LIB) -o $(GDALMODULE)
install: $(GDALMODULE)
$(INSTALL_DIR) $(INST_PYMOD)
for f in *.py $(GDALMODULE) ; do $(INSTALL) $$f $(INST_PYMOD) ; done
