[Gdal-dev] How to convert Lat/Long -> Pixel/Line ?
Frank Warmerdam
warmerdam at pobox.com
Thu May 22 13:02:58 EDT 2003
Jérôme MAUPAY wrote:
> Sorry for that simple following question, but I really don't find the
> answer in the doc:
> I convert a pixel/line to lat/long using the following code:
> bool CoxGisGdalFile::PixelLineToLatLong(int aPixel,int aLine,double*
> aLat, double* aLong)
> // Cf http://www.remotesensing.org/gdal/class_GDALDataset.html#a8
> *aLat = mGeoTransform[3] + mGeoTransform[4] * (double)aPixel +
> mGeoTransform[5] * (double)aLine ;
> *aLong = mGeoTransform[0] + mGeoTransform[1] * (double)aPixel +
> mGeoTransform[2] * (double)aLine ;
> if( !OCTTransform(mTransform,1,aLong,aLat,NULL) )
> return false ;
> return true ;
> But how to convert from lat/long to pixel/line ???
Jerome,
I realize this isn't a very fast answer. I use the following function
to "invert" the geotransform when I want to translate the other way.
/* InvGeoTransform() */
/* Invert a standard 3x2 "GeoTransform" style matrix with an */
/* implicit [1 0 0] final row. */
static int InvGeoTransform( double *gt_in, double *gt_out )
double det, inv_det;
/* we assume a 3rd row that is [1 0 0] */
/* Compute determinate */
det = gt_in[1] * gt_in[5] - gt_in[2] * gt_in[4];
if( fabs(det) < 0.000000000000001 )
return 0;
inv_det = 1.0 / det;
/* compute adjoint, and devide by determinate */
gt_out[1] = gt_in[5] * inv_det;
gt_out[4] = -gt_in[4] * inv_det;
gt_out[2] = -gt_in[2] * inv_det;
gt_out[5] = gt_in[1] * inv_det;
gt_out[0] = ( gt_in[2] * gt_in[3] - gt_in[0] * gt_in[5]) * inv_det;
gt_out[3] = (-gt_in[1] * gt_in[3] + gt_in[0] * gt_in[4]) * inv_det;
return 1;
You can see this used in GDALCreateGenImgProjTransformer() function in
gdal/alg/gdaltransformer.cpp (in CVS at least) which is documented at:
http://www.remotesensing.org/gdal/gdal_alg_h.html#a4
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
