[Gdal-dev] OpenEV 1.6.1_FW Release for Windows
Sat May 24 16:51:29 EDT 2003
Folks,
I have prepared a new build of the OpenEV_FW tool suite for Win32 platforms.
This release bring PROJ.4, OpenEV and OGDI components up to date with
current CVS versions of each.   It can be found at:
   ftp://ftp.remotesensing.org/gdal/openev/OpenEV_161_FW.zip
I hope to issue a new cut in the not too distant future that includes
MapServer (likely without any mapscript extensions, or perhaps just
Python MapScript).
I have not prepared a Linux cut of this OpenEV_FW release.
Best regards,
		Open Source GIS/RS Binary Kit for Windows
OpenEV For Windows 98/NT/2000
VERSION: OpenEV 1.6.1_FW   (May 24, 2003)
After unzipping edit the setfw.bat file in a text editor, and change
OPENEV_FW_DIR to point to wherever you put the resulting directory tree.
A sample image, utm.tif, is provided in the directory demo-data under
your install directory.  Start OpenEV by running openev.bat in a command
window, then select File, Open and double click on the demo-data directory
in the left column.  Select the image utm.tif and then OK.
See the online help for how to use OpenEV (fron the Help menu in OpenEV,
note: you must have a html browser such as Netscape or Internet Explorer
installed).
   web page:  http://openev.sourceforge.net
OpenEV was funded in part by Atlantis Scientific (www.atlsci.com)
and GeoInnovations (www.geoconnections.org).
Other Libraries, and Utilities
  o GDAL 1.1.9pre, including gdalinfo, gdal_translate, and gdaltindex, gdalwarp
    and gdalwarptest utilities.
    - Includes JPEG2000 (Kakadu), HDF4, ECW, and OGDI raster support.
  o OGR 1.1.8+, including ogrinfo, ogr2ogr, and ogrtindex utilities.
    - Includes OGDI vector, and GML support.
    - Includes FMEObjects vector reader.
    - Includes SoftmapSF.dll (OpenGIS Simple Features for COM/OLEDB provider)
      (just register it using "regsvr32 openev_fw\bin\SoftmapSF.dll")
    o Includes sfcdump.exe, an SF OLE DB provider dumper.
  o PROJ 4.4.7 plus proj.exe and cs2cs.exe
  o Gnuplot plotting package (run pgnuplot).
  o OGDI 3.1.1+, gltpd, ogdi_import and ogdi_info (includes VRF/VITD fixes)
  o Python 2.2
About this Package
This package was prepared by Frank Warmerdam (warmerdam at pobox.com) as a
handy package containing several related packages, with a maximum of
inter-component linkages enabled.  It is considerably more ad-hoc than some
of the more formal release packages, but it may have greater functionality
than formal releases.  This package aspires to be a "tool bench" of GIS/RS
tools for the end user.
