[Gdal-dev] (no subject)
Frank Warmerdam
warmerdam at pobox.com
Tue May 27 16:06:01 EDT 2003
Bill Bob wrote:
> Hi,
> I am trying to get familiar with the API by following the WarpAPI
> tutorial and also from gdalwarp.c and gdalwarptest.c.
> I have included some of my code. It appears that I do not setup the
> correct transformation. My resulting image is in the orginal projection.
> Any thoughts?
> // set projection transformer
> psWarpOptions->pTransformerArg = GDALCreateGenImgProjTransformer(
> hSrsDataset,
> GDALGetProjectionRef(hSrsDataset),
> hDstDataset,
> GDALGetProjectionRef(hDstDataset),
> FALSE,
> 0.0,
> 1
Bill,
I think the most likely problem is that the source or destination coordinate
systems are not properly defined. Trying printing out the results of
GDALGetProjectionRef() on the source and destination and see if they make
sense or post them here.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
