[Gdal-dev] problem converting to jpeg
Frank Warmerdam
warmerdam at pobox.com
Wed May 28 10:08:43 EDT 2003
Tim Smith wrote:
> I am trying to convert a NITF file into a JPEG file.
> gdalinfo shows that the NITF has a
> colorInterp=palette.
> When I use gdal_translate (gdal_translate -of JPEG
> /path/file.nitf /path/file.jpeg), the created jpeg
> file has a colorInterp=Grey. Is there a way to do
> this without the loss of color?
Tim,
JPEG does not support paletted output files, and gdal_translate does not
currently support converting 1 band paletted images into 3 band RGB images.
So currently gdal_translate cannot convert the file to JPEG in a useful way.
Do you really need it in JPEG? It should convert easily to PNG, GeoTIFF, etc.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
