[Gdal-dev] Bug in configure script when using with-geotiff
Tue Nov 4 11:07:05 EST 2003
Frédéric Trastour wrote:
> Hello,
> I think there is a little bug in the configure script of gdal 1.1.9.
> When I specify a "--with-geotiff" directory, this directory is not added to the include
> directory list but the directory specified with "--with-libtiff" is added twice.
> The problem is at line 4347 (and 4350 ) in the configure script ( the tiff dir is used
> in place of the geotiff one ).
> The related lines of the configure.in script are 331 & 334.
> Perhaps this should be corrected in the next distrib ?
Frédéric,
The problem still existed in the dev source, so I have fixed it up.  The fix
will appear in the next release.
Thanks!
