R: [Gdal-dev] gdal in debian
Amici Alessandro alessandro_amici at telespazio.it
Wed Nov 5 04:54:19 EST 2003
Silke,
> with help from Alessandro Amici, Frank Warmerdam, Paul Baker and my
> debian sponsor Jochen Friedrich I was able to get gdal into debian. If
> you would like to know more about the status of the gdal package in
> debian please have a look at
> 	http://packages.qa.debian.org/g/gdal.html
> If you experience any problems with the package please send a bug to
> the debian bug tracker. I will then do my best to solve the problem.
> Again many thanks to all those who helped me finish the package
> especially Alessandro who mainly build the package.
that's great!
the road into sarge (the upcoming stable release of debian) is still
long, but we still have a chance to make it.
first problem: portability to all the debian architectures.
Andrey, on arm and powerpc we get the following error into the hdf4 driver:
make[3]: Entering directory `/build/buildd/gdal-1.2+cvs.031016/frmts/hdf4'
/bin/sh ../../libtool --mode=compile g++ -I../../port -I../../gcore
-I../../ogr -I/usr/include/hdf -Wall  -O2   -c -o ../o/hdf4dataset.o
hdf4dataset.cpp
 g++ -I../../port -I../../gcore -I../../ogr -I/usr/include/hdf -Wall -O2 -c
hdf4dataset.cpp  -fPIC -DPIC -o ../o/.libs/hdf4dataset.o
hdf4dataset.cpp: In member function `char**
   HDF4Dataset::TranslateHDF4Attributes(long int, long int, char*, long int,
   long int, char**)':
hdf4dataset.cpp:763: error: invalid conversion from `int8*' to `const char*'
hdf4dataset.cpp:766: error: invalid conversion from `int8*' to `const char*'
make[3]: *** [../o/hdf4dataset.o] Error 1
if you so wish i can file a bug report.
cheers,
alessandro
