[Gdal-dev] How to get georeferenced pixel?
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 6 10:23:57 EST 2003
Michal wrote:
> Hi!
> I think this is very simple question. I need to get pixel value, but I have
> lattitude and longitude and not row and column information. Image is in UTM
> but I know latlong info only.
> I hope somebody can help me.
Michal,
Not really that simple a question. Andrew has posted a nice example
of reading invidual pixels based on the georeferenced location as long as
the georeferenced coordinate system is in the same coordinate system as the
image. I would suggest you get that working smoothly, and then move on to
a step to reproject your lat/long locations into UTM. Hopefully the OGR
Projections Tutorial will be helpful in this:
http://www.remotesensing.org/gdal/ogr/osr_tutorial.html
You might also find the GDALInfoReportCorner() code in gdal/apps/gdalinfo.c
helpful. That code goes the other way, from image georef coordinates (ie.
UTM) to lat/long but should show an example of deriving the lat/long
projection, creating a coordinate transformer, and then using it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
