[Gdal-dev] gdaltindex in Lastest Gdal source tree
Vincent Schut
schut at sarvision.com
Tue Nov 11 09:45:06 EST 2003
On 2003.11.11 10:53, Rick Buckley wrote:
> Hi
> I have built Gdal from the lastest source tree. All went ok ecept
> that I don't appear to have the gdaltindex program.
> In the source tree within the apps directory there is a gdaltindex.c
> file.
> Is this a common problem, does it have an easy work-around?
Not all gdal utilities get made by default. Go into the apps dir and
type 'make gdaltindex' which should do the trick if I remember well.
Cheers,
Vincent.
> Any help would be much appreciated.
> Kind Regards
> Rick Buckley
> Product Services Group
> GenaWare Ltd
> Phone: +44 (0) 161 9554400
> Fax: +44 (0) 161 9554305
> www.genaware.com
> ____________________________________________
> PRIVILEGED - PRIVATE AND CONFIDENTIAL
> This email and any files transmitted with it are intended solely for
> the
> use of the addressee(s) and may contain information which is
> confidential or privileged. If you receive this email and you are not
> the addressee (or responsible for delivery of the email to the
> addressee), please disregard the contents of the email, delete the
> email
> and notify the author immediately.
> Before opening or using any attachments, please scan them for viruses
> and defects. We do not accept any liability for loss or damage, which
> may arise from your receipt of this e-mail. Our liability is limited
> to
> re-supplying any affected attachments.
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
