[Gdal-dev] Pymod versions
Tyler Mitchell
TMitchell at lignum.com
Thu Nov 13 19:21:00 EST 2003
> I assume you mean python 2.3 vs python 2.2, right? I am pretty sure that
> the OpenEV_FW 1.6.2 distribution is using Python 2.2. However, the
python
> scripts themselves are generally ok with any python 2.x version. If you
> were to build stuff yourself it should be possible to do it with python
2.3
> and then you could use python 2.3 features if you wanted.
You're right, Python 2.3 and 2.3. I just got 2.3 removed from my system
and now I'm working okay again. I think that I couldn't import gdal into
2.3. I'll see if I can reproduce it.
Tyler
