[Gdal-dev] A change on gdal building dir?
Luis W. Sevilla
sevilla_lui at gva.es
Mon Nov 17 09:53:56 EST 2003
Done, it works but ... now I'v got:
configure: error: 'Unable to find /source/c/gdal/libgdal.1.1.so, are you
sure a
regular GDAL build tree can be found at /source/c/gdal?'
I've found libgdal.so.1.1.19 under ${GDALBUILDDIR}/.libs, and linked it
to the one that OpenEV expected to find, but ... it seems there's a
littel unsync between both projects.
Thanks for all your help
Luis
Vincent Schut wrote:
> Luis,
> gdal changed, but OpenEV has not yet adapted it's build script. if I
> remember well you can just make a symbolic link: 'ln -s gcore core'
> which would trick openev to compile.
> Cheers,
> Vincent.
> On 2003.11.17 15:21, Luis W. Sevilla wrote:
>> Hi again,
>> I'm trying to build OpenEV+gdal from sources. After building and
>> installing (make; make install), when configuring OpenEV for
>> building I've got folowing error:
>> luisw at Aplicgraf1:/source/python/openev> ./configure --with-gdal=/
>> source/c/gdal
>> loading cache ./config.cache
>> checking for gcc... gcc
>> checking whether the C compiler (gcc ) works... yes
>> checking whether the C compiler (gcc ) is a cross-compiler... no
>> Using requested GDAL_HOME of /source/c/gdal
>> configure: error: 'Unable to find /source/c/gdal/core directory, are
>> you sure a
>> There's a gcore directory under my GDAL build tree, but no core
>> directory at all. I's a change on gdal building dir or am I doing
>> something wrong ?
>> Luis
