[Gdal-dev] Trouble in link with hdf4
Fu Chen
fchen at ne.rsgs.ac.cn
Tue Nov 18 03:51:52 EST 2003
Hi!
I don't know how to link with hdf4 in win32 :<
First download the prebuilt hdf415 package and unpack it in the gdal root.
Then change two lines in nmake.opt.
HDF4_DIR = D:\gdal\HDF41r5
HDF4_LIB = /LIBPATH:$(HDF4_DIR)\libdbg
But the rebuild of GDAL report the lib collide. I know the GDAL build at /MD or /MDd. But the default build process point to a single-thread hdf lib. cl say "Automatic linking with the debug static single-threaded HDF library".
in hdfi.h
#if defined(_MSC_VER) && !defined(_MFHDFLIB_) && !defined(_HDFLIB_) /* Auto-link when possible */
# define HDF_LIB_VER "415"
# if !defined(_DEBUG)
# if !defined(_HDFDLL_)
# define HDF_LIB_NAME "HD" HDF_LIB_VER ".lib"
# pragma message( "Automatic linking with the static single-threaded HDF library - " HDF_LIB_NAME )
# else
# define HDF_LIB_NAME "HD" HDF_LIB_VER "m.lib"
# pragma message( "Automatic linking with the multithreaded HDF DLL - " HDF_LIB_NAME )
# endif
# else
# define HDF_LIB_NAME "HD" HDF_LIB_VER "d.lib"
# pragma message( "Automatic linking with the debug static single-threaded HDF library - " HDF_LIB_NAME )
# else
# define HDF_LIB_NAME "HD" HDF_LIB_VER "md.lib"
# pragma message( "Automatic linking with the debug multithreaded HDF DLL - " HDF_LIB_NAME )
# endif
# endif
# pragma comment(lib, HDF_LIB_NAME )
#endif /* def
The package of prebuilt hdf415 has four lib directories. Is the lib in the dlllibdbg what we need? where should i set the _HDFDLL_ ?
Any suggestion?
