[Gdal-dev] Can I manipulate the palette?
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 24 09:46:36 EST 2003
Kyler Laird wrote:
> I see that I can create a ColorTable and I can set it as part of
> ComputeMedianCutPCT(), but I haven't located a way to set individual
> entries. Is this something that's hidden on purpose? Is there a clean
> way to manipulate the palette?
Kyler,
The GDALComputeMedianCutPCT() produces a PCT that is good for a given RGB
image. It doesn't provide any mechanism to "guide" the selection of colors
for the color table. However, after the PCT is generated you can alter
it as you wish, adding, replacing or removing colors.
Hmm, actually, looking at the GDALColorTable methods there isn't really any
way to remove entries. But in a pinch you could just create a new color
table and copy over only the entries you want to preserve.
The C level colortable functions are:
/* Color tables. */
/** Color tuple */
typedef struct
/*! gray, red, cyan or hue */
short c1;
/*! green, magenta, or lightness */
short c2;
/*! blue, yellow, or saturation */
short c3;
/*! alpha or blackband */
short c4;
} GDALColorEntry;
GDALColorTableH CPL_DLL GDALCreateColorTable( GDALPaletteInterp );
void CPL_DLL GDALDestroyColorTable( GDALColorTableH );
GDALColorTableH CPL_DLL GDALCloneColorTable( GDALColorTableH );
GDALPaletteInterp CPL_DLL GDALGetPaletteInterpretation( GDALColorTableH );
int CPL_DLL GDALGetColorEntryCount( GDALColorTableH );
const GDALColorEntry CPL_DLL *GDALGetColorEntry( GDALColorTableH, int );
int CPL_DLL GDALGetColorEntryAsRGB( GDALColorTableH, int, GDALColorEntry *);
void CPL_DLL GDALSetColorEntry( GDALColorTableH, int, const GDALColorEntry * );
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
