[Gdal-dev] tigerpoly.py - how to use it?
Jack Twilley jmt at twilley.org
Mon Nov 24 14:31:06 EST 2003
I am an extreme newbie to GDAL, so please be gentle.
I discovered pymod/samples/tigerpoly.py and tried to use it.
I downloaded the TIGER/Line 2002 data for Contra Costa County in
California and have the following files:
total 34580
drwxr-xr-x    2 jmt  jmt       512 Nov 23 23:39 .
drwxr-xr-x  103 jmt  jmt      8192 Nov 24 10:55 ..
-rw-r--r--    1 jmt  jmt  12345480 Nov 20  2002 TGR06013.RT1
-rw-r--r--    1 jmt  jmt   3426150 Nov 20  2002 TGR06013.RT2
-rw-r--r--    1 jmt  jmt    101700 Nov 20  2002 TGR06013.RT4
-rw-r--r--    1 jmt  jmt    777954 Nov 20  2002 TGR06013.RT5
-rw-r--r--    1 jmt  jmt    228930 Nov 20  2002 TGR06013.RT6
-rw-r--r--    1 jmt  jmt     37240 Nov 20  2002 TGR06013.RT7
-rw-r--r--    1 jmt  jmt     14668 Nov 20  2002 TGR06013.RT8
-rw-r--r--    1 jmt  jmt   3030116 Nov 20  2002 TGR06013.RTA
-rw-r--r--    1 jmt  jmt     30256 Nov 20  2002 TGR06013.RTC
-rw-r--r--    1 jmt  jmt   2050240 Nov 20  2002 TGR06013.RTH
-rw-r--r--    1 jmt  jmt   6924204 Nov 20  2002 TGR06013.RTI
-rw-r--r--    1 jmt  jmt    671771 Nov 20  2002 TGR06013.RTP
-rw-r--r--    1 jmt  jmt       312 Nov 20  2002 TGR06013.RTR
-rw-r--r--    1 jmt  jmt   2429810 Nov 20  2002 TGR06013.RTS
-rw-r--r--    1 jmt  jmt   1932903 Nov 20  2002 TGR06013.RTT
-rw-r--r--    1 jmt  jmt   1117088 Nov 20  2002 TGR06013.RTZ
When I run the tigerpoly.py script using input and output directories
for arguments, I get the following shapefile:
-rw-r--r--    1 jmt  jmt  4962200 Nov 23 23:41 out.dbf
-rw-r--r--    1 jmt  jmt  4475352 Nov 23 23:41 out.shp
-rw-r--r--    1 jmt  jmt   114444 Nov 23 23:41 out.shx
shpdump tells me that this shapefile is of type polygon and contains
14293 shapes.  When I examined the output with the rendering tool I
normally use for shapefiles, it appears to have all the possible
layers jammed together.  I see water polygons, land boundaries, major
roads, minor roads, water features, everything all together.
Is there a way to generate individual shapefiles for each layer
instead of one shapefile containing everything?  I read through the
script and didn't see any way to set options to only output a single
layer per file or anything.  If I'm missing something. please let me
know as this would be terribly useful.
Jack.
Jack Twilley
jmt at twilley dot org
http colon slash slash www dot twilley dot org slash tilde jmt slash
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031124/407c9c94/attachment.bin
