[Gdal-dev] how to build with jp2kak in win32?
Tue Nov 25 09:28:14 EST 2003
Fu Chen wrote:
> Hi!
> in nmake.opt, there is
> # Uncommment if you have Frank's modified Kakadu build.
> #KAKDIR =	D:\warmerda\jp2\kakadu
> I have kakadu sdk, and build it by VisualC++. But where is Frank's modified Kakadu build? I couldn't find it in the source tree.
> any idea?
Fu Chen,
If you have Kakadu 4.0 or newer it doesn't require any special
modifications.  In Kakadu 3.x I had to hand modify Kakadu to
add support for reading and writing the JP2 box.
Hopefully you can just point this variable to your Kakadu dist
and uncomment.
PS. I have updated the comment in the nmake.opt file this morning.
Best regards,
