[Gdal-dev] Failure in opening a pci disk file
Andrey Kiselev
dron at ak4719.spb.edu
Fri Nov 28 13:31:37 EST 2003
On Fri, Nov 28, 2003 at 12:00:04PM -0500, Frank Warmerdam wrote:
> >using pcidskdataset.cpp, the open operation failed when trying to
> >fetch the number of bands of a .pix file. The returned number of
> >bands was 0. The pci disk file used was "contours.pix" from the
> >remotesensing.org ftp site under gdal\data\pcidsk.
> To the best of my knowledge this file contains only contour vectors.
> The GDAL PCIDSK translator does not support reading vector (or any
> other auxilary segment data except for the georeferencing segment).
This is right. I've just downloaded that file, it contains vectors
only.
Andrey
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
