[Gdal-dev] windows ogr2ogr including OCI
Wim Blanken (PI) wim.blanken at planet.nl
Fri Nov 28 12:42:02 EST 2003
Carlos,
I tried your solution and it worked!! I'm creating shapefiles from oracle
spatial layers in a batch file to
use as flexible snapshots for mapserver. Thanx, otherwise I would have to
compile my own version
on cygwin o.i.d. and that sure would have taken me a week or so........
Wim
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Thursday, November 27, 2003 5:36 PM
Subject: RE: [Gdal-dev] windows ogr2ogr including OCI
> Please use this http://www.sigtech-co.com/gdalOCI.zip
> This was compiled with oci support. Note that the oracle client must be
> installed prior to execute.
> Good luck
> Carlos
> -----Mensaje original-----
> De: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] En nombre de Norman Vine
> Enviado el: Jueves, 27 de Noviembre de 2003 10:09 a.m.
> Para: gdal-dev at remotesensing.org
> Asunto: RE: [Gdal-dev] windows ogr2ogr including OCI
> Julien Demaria writes:
> >            => I easy compiled GDAL with cygwin DLL but it failed with
> > -mno-cygwin when I tried...
> I routinely compile GDAL with the MingW standalone compiler from within
> a Cygwin shell.  AFAIK others are succesfully doing this from within a
> MSYS shell.
> The only thing I haven't managed to get working yet is Python support
> but I haven't tried real hard because I do most of my command line work
> in a Cygwin shell where I use a Cygwin compiled GDAL and Python.
> Cheers
> Norman
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
