[Gdal-dev] is ogr2ogr returning errorcodes?
Fri Nov 28 14:30:23 EST 2003
Wim Blanken (PI) wrote:
> Hello List,
> A simple question. Is it possible to use ogr2ogr in a batch file and
> get an errorcode back that can be used to check if the conversion
> was a success or not?
Wim,
I tried to return non-zero exit codes from programs such as ogr2ogr in
case of error. Skimming through ogr2ogr.cpp I see that I just return exit
code 1 for all errors, and return 0 on success. So you can't really determine
what went wrong from the error code, but by testing for non-zero values
you can determine if some sort of error occured.
Best regards,
