[Gdal-dev] `MULTILINESTRING' not supported
Tyler Mitchell
TMitchell at lignum.com
Thu Oct 2 14:08:01 EDT 2003
gdal-dev-admin at remotesensing.org wrote on 10/02/2003 10:41:34 AM:
> Tyler Mitchell wrote:
> > I'm working in Mapserver with a DGN file (and trying to remember the
> > lessons I learned last time :).
> > I'm getting this error, which appears related to ogr:
> > msDrawMap(): Image handling error. Failed to draw layer named
'dgntest'.
> > ogrGeomLine(): OGR error. OGRGeometry type `MULTILINESTRING' not
supported.
> > Are you familiar with this problem or is it a problem at my end or is
it a
> > bug. I've attached the renegade dgn file.
> > Here is my layer def'n in mapserver. Any ideas?
> Tyler,
> This is a MapServer/OGRLink issue. If you file a bug for it in MapServer
> bugzilla and assign it to me, I will try to fix it up. I don't
> think mapserver
> has a concept of multilinestrings, so I am not exactly sure what I
> will do with
> it.
Thanks, done.
I thought this worked months ago. I'll test against other versions of ogr
and mapserver to see.
For the sake of the list, the bug is:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=448
