[Gdal-dev] FAST: problem in UTM zone numbering
Markus Neteler neteler at itc.it
Wed Oct 8 11:47:53 EDT 2003
On Sun, Oct 05, 2003 at 07:52:43PM +0400, Andrey Kiselev wrote:
> Hi, all,
> I have fixed a problem with UTM zone numbering in FAST driver. This
> problem affects some of the FAST datasets and you can get wrong
> georeferencing sometimes. For all, using Landsat data in FAST format, I'm
> suggest update from CVS.
> As a free bonus you will get a TM projection support, which is now
> implemented in the driver.
Great work - thanks, Andrey!
Markus
Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
