[Gdal-dev] Re: Delete feature?
Thu Oct 9 11:14:16 EDT 2003
Lorenzo Sassolini wrote:
> Frank,
> using the OGR library I see that there are many methods to access
> DBMS-based datasources (Oracle) in a client-server way.
>  But it seems to me that the only way to delete a feature from a
> datasource is to save the whole layer in the datasource without that
> feature. Is it true?
> I see that for a file-based datasource this is correct, but for a
> DBMS-based datasource it would be possible to delete a single feature.
> Does exists a “workaround” to solve this problem?
Lorenzo,
I agree that the OGR API should include a delete feature virtual method, and
it should be implemented for any datasource that it makes sense for.  I am
checking support for this into CVS, and will for the time being just implement
it for the "Mem" format (in memory layers).  What drivers were you needing it
for?
As a workaround for DBMS based drivers you can use ExecuteSQL() to delete
a feature if you have a way of uniquely selecting the feature.  Note for some
kinds of DBMS sources the FID is assigned linearly while scanning and isn't
actually a field in the table.  In these cases deleting by FID can be
problematic.
Best regards,
