[Gdal-dev] porting of gdal to (optional) libtool build finally
completed
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 14 09:53:20 EDT 2003
Sy,
Thats good information. I assume you have been pleased with it so far in
actual use?
While I am in no big rush to rework the GDAL build architecture again just
now, I am wondering if OpenEV might not benefit from this. Currently OpenEV's
build structure is pretty half-assed, and OpenEV builds are currently pretty
complicated. Also, OpenEV requires Python, so we wouldn't have to worry about
gripes from the folks who don't want to have to install Python.
I will try to look at this at some point for OpenEV.
Simon Perkins wrote:
> As one of those libtool non-fans you mentioned, I can at least
> appreciate the effort required in getting libtool to work! :)
> The following is a little tangential so feel free to ignore...
> Don't know if I've mentioned this before, and if I haven't, this is
> probably a tactless time to do so... but we've recently started using an
> exciting new build tool called "scons" for our projects. The home page
> for this project is at:
> http://www.scons.org
> Scons is billed as a "make replacement" but it is actually much closer
> to autotools in scope. It works well on both windows and unix, does
> almost all of the configuration and building stuff that autotools can do
> (and is being steadily expanded), builds shared libraries, ditches make,
> has an active user and developer community and is written in python so
> it's very easy to extend. It has many nice featrues like direct support
> for parallel compliation on multi-headed machines and it uses MD4
> checksums rather than timestamps to do dependency checking.
> Scons takes a slightly different (and in my opinion more modern)
> approach to source builds than autotools. Autotools assumes that the
> normal mode of distribution of a package is a source code tarball and
> that a user must be able to configure and compile a tarball with a
> fairly minimal (UNIX-like) system. Scons recognizes that these days (a)
> most end users get their packages as binaries, and (b) developers
> working with source code can be expected to have some more powerful
> tools on their systems, such as python. The benefit of this assumption
> is a very clean approach to builds that doesn't use make. The build
> scripts that you write in scons are actually compact python scripts that
> are directly executed when you ask scons to build your package.
> Customizing your build is as simple as adding python code into the build
> script. Customizing an autotools build is typically much more cryptic
> since you are dealing with layers of different primitive languages such
> as m4, shell script, automake and the make syntax itself, and you are
> often writing code that has to write other code. Yuk!
> The main drawbacks with scons are: (a) it's not as standard as
> autotools, and (b) the documentation is currently not all that great,
> although the developers are working on it apparently!
> Anyway, just noting that there are alternatives to autotools. I'm not
> volunteering to re-engineer the GDAL build process using scons right
> now... :)
> Cheers,
> Sy
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
