[Gdal-dev] RE: Kakadu, MMS
Chris G. Nicholas
cgn at globexplorer.com
Thu Oct 16 02:27:56 EDT 2003
I have a bunch of images that look fine in kdu_show, but when I try to make MMS images out of them with GDAL, am getting just blank images with the attached MMS .map file; tried with and without the "EXTENTS" tag...
gdalinfo sees them just fine, and gdaltranslate works on them too...
hmmmm....comments/suggestions/?? welcomed...
Chris
[cgn at localhost ecuador]$ more mosaic_08_28_2003_ecuador.wld
.0021949
0
0
-.0020833
-91.388395
10.00000
gdalinfo mosaic_08_28_2003_ecuador.jpc
Driver: JP2KAK/JPEG-2000 (based on Kakadu)
Size is 9748, 9600
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 9600.000)
Upper Right ( 9748.000, 0.000)
Lower Right ( 9748.000, 9600.000)
Center ( 4874.000, 4800.000)
Band 1 Block=512x128 Type=Byte, ColorInterp=Gray
Overviews: 4874x4800, 2437x2400, 1219x1200, 610x600, 305x300, 153x150, 77x75
Band 2 Block=512x128 Type=Byte, ColorInterp=Gray
Band 3 Block=512x128 Type=Byte, ColorInterp=Gray
[cgn at localhost ecuador]$ gdalinfo r309.jp2
Size is 4800, 8400
Corner Coordinates:
Lower Left ( 0.000, 8400.000)
Upper Right ( 4800.000, 0.000)
Lower Right ( 4800.000, 8400.000)
Center ( 2400.000, 4200.000)
Overviews: 2400x4200, 1200x2100, 600x1050, 300x525, 150x263, 75x132
Type: application/octet-stream
Desc: test2.map
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031015/76c44fe3/test2.obj
