[Gdal-dev] error because of libtool?
Vincent Schut
schut at sarvision.com
Thu Oct 16 06:35:57 EDT 2003
Alessandro,
That was also my first guess, as there are two instances of '-Lyes' in the last shown line. I do not have any --with-bla=yes in my configure however. I just retried after a cvs up and the problem is still there. Compiling without-libtool works OK.
These are my configure options:
#!/bin/bash
#gdal configure script
./configure \
--with-libz \
--with-png \
--with-geotiff=internal \
--with-jpeg \
--with-hdf4=/usr/local
Cheers,
Vincent.
On Thu, 16 Oct 2003 09:47:00 +0200
Amici Alessandro <alessandro_amici at telespazio.it> wrote:
> [i alredy replyed to this mail from a different account, but some of
> my mails get stuck, Frank do you have any clue?]
> Vincent,
> > /bin/sh ./libtool --mode=link g++ -lodbc -L/usr/local/lib -lmfhdf
> > -ldf -ljpeg -lpng -Lyes -Lyes -lz -lm -ldl -L/usr/lib -lpq
> > -o libgdal.la ./frmts/o/*.lo ./gcore/*.lo ./port/*.lo ./alg/*.lo
> > ./libtool: line 1: cd: yes: No such file or directory
> > libtool: link: cannot determine absolute directory name of `yes'
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory `/usr/local/src/gdal'
> > make: *** [check-lib] Error 2
> my guess is that you are using '--with-*something*=yes' and configure
> is now using 'yes' as a search directory for libraries (!!).
> if you give us the complete configure command line you used we can
> probably restore the correct behaviour, in the mean time just use
> '--with-*somethnig*' without '=yes'.
> cheers,
> alessandro
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
