[Gdal-dev] Gdalwarp resampling
Matt.Wilkie
Matt.Wilkie at gov.yk.ca
Thu Oct 23 13:50:34 EDT 2003
Hi Frank,
On the page http://gdal.maptools.org/gdal_utilities.html at the end of the
'gdalwarp' section it says:
Mosaicing into an existing output file is supported if the output file
already exists.
It currently has the following limitations:
* Only 8 bit data is can be warped.
* The entire source image is held in memory.
* Only nearest neighbour resampling is available.
Do these limitations apply only to mosaicking or to all gdalwarp options
generally?
Thanks,
-matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
