[Gdal-dev] gdalwarp output
Matt.Wilkie
Matt.Wilkie at gov.yk.ca
Tue Oct 28 11:52:43 EST 2003
> (since no pixel down sampling is available in gdal_translate,
> correct?) which can be quite memory intensive since
Happily incorrect :)
" -outsize xsize[%] ysize[%]: Set the size of the output file. Outsize is in
pixels and lines unless '%' is attached in which case it is as a fraction of
the input image size."
http://gdal.maptools.org/gdal_utilities.html
Cheers,
-matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
