[Gdal-dev] IRasterIO in Dataset
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 30 00:00:22 EST 2003
Fu Chen wrote:
> Frank,
> Yeah, this code is more safe. Thanks.
> But I find the ecw supersample is very slow indeed when my little browser
> to set the zoom ratio more than 1:1. Is there any reason?
Fu Chen,
For some reason the ECW libraries won't do supersampling. I could try and
implement it directly within the ECW driver but that is lots of work, so
to be safe (and lazy) I force things through generic level code reading
full scanlines from the ECW driver when supersampling.
The result is terribly expensive in IO.
It could be fixed, but would be a fair touch of work to do properly.
Later,
and watch the world go round - Rush | Geospatial Programmer for Rent
