[Gdal-dev] porting of gdal to (optional) libtool build finally completed
Alessandro Amici
alexamici at tiscali.it
Thu Sep 25 15:27:10 EDT 2003
folks,
it has taken a good two months, but i'm finally ready to announce that the
optional libtool build is now ready for prime time :).
this should allow setting proper soname versioning on all supported systems
and as a bonus we should be able to build standard shared libraries on a wide
variety of previously unsupported unix and unix-like systems.
in order to try it you just need to append '--with-libtool' to your normal
configure command line.
in order to test system independece i built gdal on linux, cygwin and a
cross-compile to mingw32.
on linux i could successfully test different combination of internal and
external help libraries, in particular:
libz ext/int
grass not tested
cfitsio ext
png ext/int
libtiff int
geotiff int
jpeg ext/int
gif ext/int
ogdi not tested
fme not tested
hdf4 ext
jasper not tested
ecw not tested
kadaku not tested*
mrsid not tested
pg ext
xerces not tested
* judging form the GNUmakefile kadaku support is not going to work.
last but not least, i tested python support on linux-python2.3.
on cygwin i could verify that most of the raccomandation from Norman on how to
build and install the libraries are actually automatically taken care by
libtool.
the mingw32 host needs an annoying work-around (build with 'make LIBS=') in
order to build the shared library. the static library is always built
correctly.
now, i know that a few people on the list are no fan of libtool and they
certainly have good reasons (like a 30% to 300% (!) increase in build time!).
OTOH moving the default build to libtool can simplify substantially the build
infrastructure. and the portability advantages are also obvious.
a way to keep the advantages of using libtool without incurring in the worse
disadvantages during development is to move the default build to libtool (so
normal users will get that) and switch to the native build with a
--without-libtool configure option (that will be used by developers).
since tha native build is targeted to developers (that is, mainly Frank and
Andrey AFAIK) we can restrict it to only work on unix/linux with gnu build
tools.
Frank, what's your opinion? isn't it tempting to support all unices with just
one set of configure-makefile rules?
questions, comments and test report on other systems are welcome.
cheers,
alessandro
