[Gdal-dev] GDAL Utilities Documentation
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Apr 2 17:10:24 EST 2004
http://www.remotesensing.org/gdal/gdal_utilities.html
A few docco correcttions/enhancements. Additions or changes are
[[demarked like this]].
Typos and Clarifications
# gdal-config - Get options required to build software using GDAL[[,]]
against GDAL.
#Creating New Files > -a_srs: the EPSG bullet paragraph is repeated
#General Command Line Switchces
--optfile file:
Not sure where in the document this should go, but it would nice if
there were an example showing it's use, e.g.:
gdal_translate -optfile tiff-opt.txt utm.tif utm_comp_tiled.tif
contents of tiff-opt.txt:
-of gtiff
-co TILED=YES
-co COMPRESS=PACKBITS
-co TFW=YES
-a_srs '+proj=UTM +zone=11 datum=nad83'
is the same as:
gdal_translate -of gtiff -co TILED=YES -co COMPRESS=PACKBITS \
-co TFW=YES utm.tif -a_srs '+proj=UTM +zone=11 datum=nad83' \
utm_comp_tiled.tif
gdal_info:
o. Raster size (in pixel[[s]] and lines).
gdal_translate:
-srcwin xoff yoff xsize ysize:
Selects a subwindow from the source image for copying. [[Corners
given in pixel coordinates.]]
gdal_warp:
-wo "NAME=VALUE":
Set a [[lot]] of warp options....
Suggested Changes
--help-general:
Why be so specific? Better to use '--help' for general help. This is how
most linux utilities seem to work.
--format format-name
Might make more sense to use '--help format-name' instead.
gdal_warp:
-rn, -rb, -rc, -rcs:
Better to harmonize with with gdaladdo -r {nearest,average,...}
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
